Small Fuel Tank under hood? (Name that part)
Car: 1987 Trans Am
Engine: 383 Stroker
Transmission: 700r4...sort of
Hey guys,
I am having problems starting my car (have a thread for that) and i think i narrowed it down to one specific part along the fuel line. There is a cylindrical container between the windshield washer fluid and headlight that connects a fuel line (coming from tank i assume) to the carburetor. After pulling the throttle to check the carb and fuel line from that container it turns out that the fuel never actually leaves that container. I can however smell it in there, and it's simply not reaching the carb like it should.
It has a label on it saying Fuel Tank, but I was wondering if there was a specific name for it and if you guys have it in your cars as well, also if you know how I can test to see if it works and what it does in general. I have a 383 swap that was performed by the previous owner's mechanic.
Please and thank you. If you guys need it, i can try and take a photo but it's very hard as i don't have a camera.
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Small Fuel Tank under hood? (Name that part)
That is a charcoal cannister, it's part of your evaporative emissions system. It is designed to scrub the fuel vapor coming from the tank.
Car: 1987 Trans Am
Engine: 383 Stroker
could it be the culprit for not delivering my bloody fuel?
No, no affect on it at all. If you aren't getting fuel it is a pump or a filter problem.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If its not working right, the tank wont vent right and it will screw with ya.
also the CCP valve that cotrols that is one rat bastard
1992 Trans Am
05-10-2023 07:19 PM
theshackle
03-05-2017 06:37 PM
