IAC question
Car: 1989 IROC-Z
Engine: 5.7L V8 350 TPI
Transmission: Automatic
IAC question
Rookie question, but how should I go about "unscrewing" the IAC from the throttle body?
Car: 1989 IROC-Z
Re: IAC question
What I mean is; whats the best way to reach it? Anyone?
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: IAC question
I just removed the throttle body on the last one I changed out.
Re: IAC question
If you are trying to clean the IAC, you should really pull the TB and clean the passages also.
Car: 1989 IROC-Z
Re: IAC question
Sorry for the craptastic pic, but is that red thing my idle stop plug?
Car: 1989 IROC-Z
Re: IAC question
The red thing is a vacuum cap that is covering the vacuum port for your charcoal canister.
To my knowledge there is no such thing as an idle stop plug. There is a throttle stop, which is on the other side where the linkage is, it prevents you from "over opening" the throttle blades.
Car: 1989 IROC-Z
Re: IAC question
Okay, makes sense. What I'm looking for is the Minimum air adjustment screw..
Saw a pic that had it on the upper right corner of the throttle body, but it's not there on my car... it's an 89 IROC-Z 5.7L 350.
Re: IAC question
It's covered with a cap that you have to knock out. It on the top driverside corner of the TB. Right where the linkage is.
I am assuming you are having idle issues? if you have no vac leaks or other problems, follow this article.
https://www.thirdgen.org/tpimod2
Car: 1989 IROC-Z
Re: IAC question
Yup idle issues...
when I start it, it idles high at first, then jumps around, then stalls.
Car: 1989 IROC-Z
Re: IAC question
Yup. I am almost positive there is a vacuum leak.
First I am going to find and repair the vacuum leak, then I am going to give a good cleaning to the IAC and throttle body.
Then, I am going to make sure everything is set correctly.
Just need to make sure I know how to do everything. Thanks for your help!
