Engine Reving high, brake stiff
Car: 92 Firebird
Okay, i just changed my water pump out in my 92 Firebird and flushed the radiator. I thought we did everything successfully, but upon starting it, it will idle up to 3000 revs and the brakes are frickin stiff to the point that i have to use to E-brake to come to a complete stop. The revving fluctuates up to 3000 and down to regular idling level.
I have no clue what we did, could anyone give me some isnight?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Engine Reving high, brake stiff
sounds like the big vacume hose to the brake booster
got knocked loose-that being off will cause both of the
problems you describe
Car: 92 Firebird
