Choppy idle/no start TPI
Car: 1974 caprice
Engine: tpi 400
Transmission: turbo 350
Axle/Gears: i was robbed of this knowledge
1974 caprice TPI 400
compression, visible spark, air, gas but it wont idle
About a week ago i left it outside the garage now it wont start. If i leave it alone for a hour the plugs will dry and it may or may not catch and idle for about a minute. If it does idle i get no misfires just a ugly choppy low rpm idle. If it doesnt catch and start the plugs get soaked in fuel and it gets harder and harder to start.
Its a TPI 400 so the clear flood mode should kick on but i guess it doesnt. Im not getting any codes. Starting fluid doesnt change anything. The way it idles(when it does) I was thinking the timing chain but i got good comp so im stumped.
Car: 1974 caprice
Engine: tpi 400
Re: Choppy idle/no start TPI
-parts replaced for problematic reasons are fuel pump, tps, ignition module, ECM and magnetic pickup coil
-brand new fuel filter, air filter, wires, plugs, cap, rotor, and ignition coil just for tune up
COMP NUMBERS
160-8 7-153
155-6 5-155
150-4 3-153
151-2 1-155
I did not do a leakdown test or wet test, the heads are rebuilt
COMP NUMBERS
160-8 7-153
155-6 5-155
150-4 3-153
151-2 1-155
Car: 1974 caprice
Engine: tpi 400
I got alot more details but i find that if there is too much to read people wont read ask and ill answer to the best of my knowledge any kind of help would be appreciated
Sanjay
08-12-2015 04:41 PM
