350 crate from mexico
Old 04-21-2011, 10:28 AM
RussC's Avatar
so i've been trying to figure out what i have for a motor and have found lots of info here, thanks to the search feature. i'm only stuck with one set of numbers. i'll start off with what i have: its a 350 crate from mexico (block casting 10066036). i'm assuming the heads are the garbage ones that came with it, havn't had time to check yet. i think i figured out one set of the numbers on the front under the pass side head (1m0627 may mean chevy made in mexico on june 27).
the 2nd set of numbers in the same spot that i found the date are the ones that i'm having trouble with. it reads 6h04. everything i found only has 3 letters/numbers combo. anyone have any insight on this code or is it just something that really doesn't mean anything?
Old 04-21-2011, 11:10 AM
RussC's Avatar
Re: 350 crate from mexico
i'm also planing to do a small build to this motor since i have a set of vortec heads on the shelf. since its not a roller block i'm thinking of this cam http://www.summitracing.com/parts/CCA-12-402-4/ . its Duration at 050 inch Lift
212 int./218 exh.Advertised Duration
260 int./268 exh.
i'm planing on keeping the tpi intake, don't want to go carb and can't afford the other intakes. so what do you think?
Old 04-21-2011, 11:54 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
New or used?
That may seem like a dumb question sence described it as a crate motor but just for confirmation sake...
Old 04-21-2011, 11:56 AM
TNT_Z28's Avatar
Also, what motor did the car have originally
305 or 350 tpi?
Old 04-21-2011, 12:10 PM
RussC's Avatar
its used cause thats what is still in it. it was originally a 350 tpi according to the rpo codes and vin. i'm guessing the motor was put in back in the early 90's so it may have been done by the dealer. the guy i bought it from didn't do it, neither did the guy he got it from, i talked to them both. that covers from about 1998 or so till now.
Old 04-21-2011, 12:24 PM
TNT_Z28's Avatar
Inthat case, do th basics...
Front and rear seal, pan gasket, etc. If you replace the heads and cam it might be a good idea to rebuild/remachine the shortblock. No time like the present...
Old 04-22-2011, 08:35 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The Targetmaster GM remanufactured engines were a cheap way out when dealers or anyone else had to replace a motor. Whoever owned the car at the time that was done got the short end of the stick. The factory replacement for the L98 long block is what should have gone into the car but the dealer went cheap. Probably some lubetech forgot to put oil in it and destroyed the original motor. The Targetmasters are no longer made as far as I know. It's all Goodwrench now. The Goodwrench engines are very good for the price.
Old 04-22-2011, 03:02 PM
RussC's Avatar
so would that be a good cam with vortec heads? or should i go with something a lil bit smaller?
Old 04-22-2011, 05:39 PM
TNT_Z28's Avatar
thats not too big at all....
Old 04-22-2011, 06:25 PM
RussC's Avatar
thanks for the help, should be fun playing
Old 05-18-2011, 09:57 AM
RussC's Avatar
ok so i went to my shop to order my cam and got talking to he guy there and he thought that cam was too small and suggested this one, its a whole kit.
Advertised Duration
262 int./270 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.464 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.470 in.
http://www.summitracing.com/parts/CCA-K12-262-4/
what do you think? should it fit fine or will the head need some machining?
Old 05-19-2011, 09:52 AM
RussC's Avatar
*bump*
Vojtush31
10-11-2015 01:07 PM
89fast5oh
09-08-2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
09-07-2015 07:17 PM
FtrSpeedy
09-07-2015 12:11 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: 350 crate from mexico
