Ethanol 30 Can i run my camaro on it..???
So i have a 1989 camaro and i was wondering if i would be able to run it on some e30 i know i will loss power and econ but idc gas is killing me.
If anyone know wer i can fill up on e30 close to north west indiana michigan city txt or pm me
219-561-1976
219-561-1976
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: Ethanol 30 Can i run my camaro on it..???
You should not use E30 without rejetting, you will be too lean.
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
some of the best gas you can run in you car is non-oxygenated gas...
otherwise known as gas with absolutely no ethonal
Ethanol is BAD for anything that isn't tuned or designed to run on it. SEMA has been fighting E15 for all vehicles built before 2009 or 2010.
http://www.semasan.com/main/main.aspx?id=62807
Even though E30 and E10 is cheaper, calculate your cost per mile driven. Typically it's cheaper per mile to use no ethanol than to fill up w/ E10, even though the price per gallon is cheaper.
Take the cost of a gallon of gas and divide by your actual MPG.
I have to 2nd Oxy if you can find it.
You could probably find it on the Internet somewhere. Ive found websites that list the stations.
I'm lucky enough to have a sinclair station that sells 93 n/o a block away from where I work. Half a mile down the road the airport sells 110 oct
92camaroJoe
08-13-2015 06:07 AM
