Which Spark Plugs
Old 04-10-2011 | 01:03 AM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Which Spark Plugs
Ok so i ordered plugs for my camaro. There taper seat. the ones i pulled out are a gasket seat. Can I use the taper seat? im not even sure if the gasket seat ones are the correct ones because the guy I bought it from wasnt the smartest so he could have put the wrong ones in. its an 88 5.7 iroc-z.
Old 04-10-2011 | 07:43 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Which Spark Plugs
Taper seat are correct. Probably R45TS.
Old 04-10-2011 | 09:27 AM
Tapered seat plugs were introduced in the early 70s. All SBC heads since around 73 have had them. Unless your heads have been swapped, that's what you need.
You can check the head casting # to make sure what heads are REALLY there.
Wouldn't be the first time some PO had either swapped something, or just made an ignorant mistake.
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
db057
04-28-2019 07:45 AM
Jlanz55
09-09-2015 09:09 AM
90formulaVortec
09-08-2015 12:42 AM
89 formula TPI
09-07-2015 11:06 AM
Quick Reply: Which Spark Plugs
