Any one have this cam?
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Does anyone have the lunati p/n 00010 and do you like it? and do you have a video of your car running so i can hear how it will sound lol gonna put it in my 350 when the weather gets warmer and complete my v6-v8 swap
CAM SPECS:
Advertised Duration (Int/Exh): 292/292
Duration @ .050 (Int/Exh): 230/230
Gross Valve Lift (Int/Exh): .480/.480
LSA/ICL: 109/107
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2000-6000
CAM SPECS:
LSA/ICL: 109/107
Car: 84 firebird
Engine: 355
Re: Any one have this cam?
No one has this cam? come on anyone? lol
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Thats their old bracket master cam isnt it? Not bad on a carbed app not the most ideal for EFI/TPI.
Go smaller imo
60101 lunati for example or maybe Oz's suggestion
Go smaller imo
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
I had it and with stock 1.94s 8.5:1 compression with a holley intake and carb made 262hp and 320 ft.lbs at the wheels
