Do i really need a thin head gasket???
Old 02-28-2011 | 08:44 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Transmission: 700r4 auto
Axle/Gears: ??????
I have flat top piston's for my 350 build and I thought I needed a thin head gasket to up compression since my motor is the low comp 79 z28 shorty .....but the guy at autozone told me that a thin head gasket would be pointless??? If he's not right.. what size should I use?
79 350 from z28
Trw flat tops
Comp cam 284 dur 481 lift
291 camel humps (for now)
Edelbrock performer air gap
Q-jet 750
Headers
Dual exhaust
Posi
Old 02-28-2011 | 09:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Do i really need a thin head gasket???
Nothing wrong with using a thin head gasket. How thin depends on what type of gasket you want to use. The aftermarket composite gaskets are actually thick. A MLS gasket which is the best way to go is very thick. The factory used a thin steel head gasket for many years and is the thinnest you can go. I believe the factory steel gasket is only 0.018".
Using a thin head gasket means the valves are also closer to the pistons. You should check the piston to valve clearance with the new gasket before firing up the engine. Pushrod geometry should also be checked.
Old 02-28-2011 | 10:04 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
So a thin head gasket isn't necessary for upping compression with my flat tops?? I'm asking cause someone said flat top piston's without a thin head gasket was a waste.
Old 02-28-2011 | 10:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Depends on the combustion chamber size in the heads and what the compression ratio is with different thickness head gaskets.
Old 02-28-2011 | 10:13 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
63cc on heads
Old 03-01-2011 | 12:06 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Find the different gasket thicknesses and do the calculations to get the compression ratio you desire.
http://www.wallaceracing.com/cr_test2.php
Old 03-01-2011 | 12:36 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
With a common head gasket such as the Felpro Permatorque, you will be right at 10:1 CR. Assuming that your flat tops are the common 4 eye brow valve relief type. That's about right for your cam. The Permatorque will provide much better sealing and a longer service life than the thin steel.
Old 03-01-2011 | 12:42 AM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Thanks guys
Old 03-01-2011 | 03:25 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
in addtion to whats been said, there is something more important than compression that you need to take into consideration before choosing the head gaskets, the quench.
you want quench to be around .040~0.050.
if the pistons are at zero deck height and you use a thin shim gasket, the pistons will be too close to the heads.
too much quench and you'll have detonation problems.
Old 03-01-2011 | 07:34 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
..finally, somebody mentioned quench.....THE major advantage of decking a block or running a thin gasket!
Tighten it down to .030-.035" (assuming hyper pistons, close bore fit, and minimal piston rock at TDC). Reduced quench clearance will always allow your engine to tolerate more compression because of the low rpm mixture motion that the quench/squish provides.
Unless your block has been decked where the pistons are less than .015 in the hole, run the Felpro 1094 rubber coated .015" shim gasket.
Ps. Don't worry much about what your typical guy at Autozone says!
Old 03-01-2011 | 12:19 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
I dont see any mention of sealing problems and whether or not the heads and block were surfaced to be totally flat.
Old 03-01-2011 | 12:24 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Cool...I appreciate all the info.
Old 03-01-2011 | 12:55 PM
86LG4Bird's Avatar
Good you pointed that out. I was assuming with his rebuild that all of that was guaranteed.
With that being said, I've used the coated .015 shim gaskets on "re-assembles", not necessarily rebuilds, without resurfacing, with never any problems. Just checked deck and heads for flatness.
3rd gen money
09-09-2015 12:40 AM
355tpipickup
08-27-2015 09:13 AM
NinjaNife
08-23-2015 12:49 PM
qz6lwp
08-20-2015 09:10 PM
Quick Reply: Do i really need a thin head gasket???
