Beehive LS6 springs, what else do I need?
Old 02-24-2011 | 02:50 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Ok building my 350. Going to use LS6 springs, I know there are some special retainers I need to use but I don't know the part # . I've tried searching but I cannot find the correct #. anyone have that? Anything else I need besides the retainers? What about valve locks?
Old 02-24-2011 | 06:32 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Re: Beehive LS6 springs, what else do I need?
not sure why this was moved, this is about my TPI and more specifically my TPI heads..
Old 03-05-2011 | 11:54 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Comp makes a retainer for 11/32" valves and beehive springs - uses stock locks.
If you're running 8mm valves, then stock LS1 retainers and locks work.
Old 03-05-2011 | 12:59 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I run comp 26918 behives... 787 retainers.....4705 spring locators.....601 locks... also need a micrometer for behives to get correct install height Comp 4930.
LT1Formula
10-08-2015 09:34 PM
Galaxie500XL
10-01-2015 02:05 PM
