Piston ring sizing
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Piston ring sizing
What is the reason behind that forged pistons have 1/16" top ring why normal hyper pistons have 5/64" rings?
Edit: corrected size.
Re: Piston ring sizing
You can get pretty much any piston material in any ring width you want on a small block Chevy. Thinner rings are generally lower friction but it's their WEIGHT that is the biggest difference. In high RPM applications thinner rings have less tendency to "flutter" and lose seal at higher RPMs. That's why higher performance stuff will usually use thinner rings. Friction has more to do with the tension of the rings. GM has used low tension rings in most of their motors for more than 20 years now. Then they went to metric rings, which are about equivalent to 1/16" rings in thickness.
Car: 1992 Camaro RS
Engine: 3.1L V6
UltRoadWarrior9
09-02-2015 08:24 PM
