Big Block cam ID?
Car: 1994 Z28
Engine: 355 LT1
Big Block cam ID?
I pulled the cam out today, trying to figure out the specs.
It's stamped "CWC" towards the back of the cam between two lobes, the back of the cam says "M215" and "951944". Then between the lobes all over the cam are two digit numbers (ie "13"). Anybody able to give me any more information on the cam? It's a flat tappet setup.
Car: 1989 firebird formula
Engine: 5.0L V8
Re: Big Block cam ID?
Personally I would start with the body work. But that's because I know what to do. Like you I have limited knowledge of engines
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
CWC is the manufacturer of the cam blank. 215 is probably the duration which is pretty mild. It's quite possible it's a simple TRW factory replacement camshaft. Nothing special.
Car: 1994 Z28
Engine: 355 LT1
From what I've been told by the local shop that built it, it was a low duration high lift cam. The guy who originally built it doesn't remember the specs and the owner can't find the cam card so I was trying to figure it out.
gixxer92
09-01-2015 04:32 PM
