need help iroc wont start!!!
1 Post
Car: 1992 convertible camaro 1992 z28
Engine: 305 tbi 5.0 tpi
Transmission: 700r4 700r4
Axle/Gears: 2:73 2:73
Hi i need some help with my iroc its getting weak spark can weak spark keep it from turning on? it just turns over but wont fire up fuel pump is fine. we got it started last weekend by cleaning the ditrubutor cap and fully charging the battery. we did the same thing 2 days ago but it just turns over any advice i want get it started this weekend that way i wont have to take it to a mechanic battery is fine it starts up my brothers 91 z28 and my 92 rs
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: need help iroc wont start!!!
Depending what year your IROC is you can swap coils with one of the other Camaros. Also make sure there is full volts going to the power wire of the coil.
1 Post
its a 1988 iroc plug wires are a little bad will be changing them this weekend so weak spark will keep the car from running
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Ok so you don't have the 86 and older coil in the cap HEI so you can also try swapping the coil with one of the other camaros.
And yes, a weak spark can keep it from running.
Also, a fully charged battery will measure 12.6 volts and 12.3 is cosidered half charged. With the draw of the starter on a weak battery your volts may be dropping that way and not getting enough power to the coil.
So maybe make sure your battery is fully charged, try a coil off on of the other camaros if you can and check volts to the coil.
May also check the wires to the module. Perhaps when you cleaned the cap youmoved the wires a bit. The module is located in the distributor. If needed places like Autozone can test the ignition module for free. You just need to take it out of the distributor.
1 Post
Car has good spark after i changed wires but it onl;y starts if i put starter fluid and it stays on is it the maf sensor?
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
If it starts with fluid then the ignition is working. You must be having a fuel related issue.
Does it start and run after spraying starter fluid or immediatly die once the fluid is burned off?
1 Post
it starts and runs i can shut it off and turn it back on but if i let it sit for an 1 or so it wont start back up
1 Post
meant to say if i let it sit for an hour or so it wont start up
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
And you can hear your fuel pump prime when you first turn the key on?
I wonder if you may have a problem with your cold start injector.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I can't find mentioned in any of my manuals the location of the Thermo Timer Switch. This would send a ground to your cold start injector when the engine temps are low.
I did search the forum and found a couple of threads. Maybe this one will help you.
https://www.thirdgen.org/forums/tpi/...ting-woes.html
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
and this one,
https://www.thirdgen.org/forums/tpi/...eded-hard.html
1 Post
yeah i hear it run for about 3 or 4 seconds
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Then you might look into the cold start injector and its thermo timer switch.
Those two threads I posted the links to should help with that. One went over cleaning the injector and the other I saw mentioned the location of the thermo switch.
You might start by checking for power and a ground to the wires on the cold start injector while the motor is cold. If you have both of those then maybe the injector needs cleaning.
mustangman65_79
08-11-2015 03:17 PM
