slugish
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: slugish
TBI, TPI, Carbed? Sluggish on highway, putting around town, both? Any backfiring? Have you checked for vacuum leaks? What mods (if any) has been done? Have you checked timing? Checked firing order? Checked for spark at each plug? Have you changed fuel filter?
Could be anything - maybe your foot has a cramp in it? more info!
Car: 88 camaro
Re: slugish
lol ok when im take off it acts like it slugish to shift out of first gear so i press down on the gas and it picks up speed it seem like it just acts slugish when i'm n 1st try to go to 2nd i checked the tran fluid and its ok. I think it might be my exhaust because the exhaust that on my car isnt set up right . On each side its two pipes from the headers to the mufflers and they are hanging when i hit a dip or something they rub the ground
Car: 1992 RS
Engine: Carbed 350
Re: slugish
Any cat converters in there? If not, maybe not nough backpressure in the exhaust system. If so, maybe one or other is clogged (kinda doubtful - if there's cats there, then they should be fairly new since this isn't stock exhaust).
Hope you're not mad - wasn't trying to be a jerk, just adding some humor!
Car: 86 Trans Am
godreject
05-25-2009 12:02 AM
