About how much horsepower should this setup have?
Car: 1988 Trans Am GTA
Engine: 350 5.7
How much horsepower should this setup have with a good tune?
1988 Trans Am 5.7
headers
3 in catback
slp high flow runners
58mm throttle body
1988 Trans Am 5.7
headers
3 in catback
58mm throttle body
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: About how much horsepower should this setup have?
58mm TB waste of $$$ on stock motor
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
you should gain about 60-80hp to the original amount. I believe that those 5.7' had about 210hp so you have about 270-290hp. However, you will loose low-end power but you should notice a good amount of power in the 4000-6000 rpm range.
If you don't mind me asking ( camaro305sb ) what's wrong with my answer. My dad had a 88 formula 350 and that car had 220hp from the factory and its the same 5.7tpi i would think.
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
1 Post
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
do you know what 80 HP is? he will be lucky if he gets half of that with only does mods
Mark.
LT1Formula
10-08-2015 08:34 PM
