Dallas Cast Iron Block Welder Recommendation
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I'm hoping someone can recommend a welding business in the Dallas, TX area that can weld up a small block coolant leak at the bottom of one cylinder.
The shop that did the clearancing for a stroker crank broke through so it's repair time.
Thanks for any help.
Jake
Jake
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Dallas Cast Iron Block Welder Recommendation
put in some block filler,forget welding cast iron.
Axle/Gears: 3.07
Nope, block's already half filled. Welding is my only option now to save the block. Welding isn't as it once was - difficult to do successfully - just finding a shop that specializes in it becomes the biggest problem.
Even the magazines techs, doing an engine build for one of their issues, occasionally ground through and repair their blocks.
Jake
Jake
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The block is filled and it's still leaking?
Axle/Gears: 3.07
Axle/Gears: 3.07
Engine: 383 Carb
Transmission: 4L60
Could you braze it instead? It's going to take a big oven and hours and hours of slow cool-down time to furnace weld a block, and it's pretty much guaranteed to warp and need to be remachined.
Axle/Gears: 3.07
I've researching the cast iron repair techniques. As with most things, there different views/recommendations on what and how to do it.
I prefer to stick to the most often recommended method and actually performed by a business/shop that does these types of repairs as part of the regular business - not some less frequently recommended (trick of the week rod) or some shop that does it as a side business. Shops that offer on-site welding of cast iron Caterpillar engine blocks and other types of heavy duty machinery, diesel truck engine welding, etc. See what I mean?
Yes, I fully expect to use the oven method since it's the most frequently recommended, and the cool down procedure (which is posted as being so important) is not a problem for me either.
Full machine work is going to be done to the block, by Reher and Morrison, once the leakage is repaired. The block will be pressure tested at LEAST four more times.
Back to my original request: Does anyone know of shop they'd recommend?
Jake
Engine: 383 Carb
Transmission: 4L60
The cool down isn't a problem, but it's lengthy and the whole process will probably be pretty expensive. A new block is probably going to be cheaper, what's special about this one?
Axle/Gears: 3.07
Welding runs around $75.00 but money's not a concern. Finding a shop that's proficient in welding a cast iron block coolant leak, however, is.
If by "new block" you mean, literally 'NEW" I'd take a quick pass. I'm much have one out of a schoold bus, taxi cab or police car. Something like that.
I'm beginning to think no one here has a recommendation. No problem, I'll just post it on a few other Forums to see if anyone there has one.
Jake
Car: 1987 Monte Carlo SS
Transmission: 200R4
Got any tower/pipe builders in the area??
They should be more than able to weld the block.
I am not a vast experienced welder, just kinda learned it along the way since I am my shops millwright of sorts. I can weld cast no problem as long as its 1/8th or more thick on our machine equipment by preheating the cast til cherry hot and using a 1/32 special cast wire on a old mig welder. Its strong and holds up well as long as I let it air cool since the stuff I'm working on can't be placed in a oven, just a tad too large.
It seems to some degree you may have answered your own question. Look through the yellow pages for large machine engine rebuilders/machine shops. You should find one that does cast block repair. Does your machinist have any recommendations? Here in my area, Somer's Automotive Machine is among the best and does all my machine work. If he cut through a block, he would know who to have repair it.
UltRoadWarrior9
04-28-2020 10:39 PM
