Should the alternator "hum" with key on and engine off?
Like the topic says. I noticed in the garage when its quiet that if i turn the key on and the engine is off i can hear the alternator "humming". I verified that the sound is from the alt. It seems to be charging alright, i was just concerned about the "humming". Any thoughts?
Re: Should the alternator "hum" with key on and engine off?
Doesnt smell burnt or hot, though i havent left it with just the key on for any length of time (may not want to do that if there is a problem!). Is there any thing in the ECM that could be causing this?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I also had this problem, but I've never heard it before on any of the many GM cars I've owned.
I talked to a guy that's an engineer for an alternator manufatcurer, and he says it's a piece of metal that isn't secured exactly right inside the alt. He says it has no bearing on how the alternator functions.
Just for fun, I opened the alt just to take a look. I couln't find anything obvious, so I put it back together and it still humms and charges.
1 Post
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Forget about it, the alt on my camaro has been doing that for about a year and works perfect. Yours isn't a reman by chance is it? That's what mine is.
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
