SERVICE ENGINE SOON?? WHAT'S UP?
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
OK,PUT NEW PLUGS IN CAR,BUT NO WIRES YET.
THEY LOOK FINE,BUT HOW CAN YOU TELL?
HERE IS WHAT IT IS DOING.
when you come to a stop sorta fast engine dies.
seems to have a miss when you first crank before engine gets warm.
sometimes when you punch it the car just looses all power
and service engine soon light comes on.
i have also noticed a hesitation at normal shifting thru gears.
any ideas what problem is?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: SERVICE ENGINE SOON?? WHAT'S UP?
Grab a paperclip, and read: https://www.thirdgen.org/service-eng...ht-error-codes
You can't usually see problems with plug wires. or dist caps, or rotors.
how do you run the ses codes?
do you have to take it to a garage?
does it take special tool?
thanks all,
jd
thanks all,
jd
backtothe80s
09-05-2015 12:39 AM
