Left ignition on all day, won't turn over now.
Car: '84 Trans Am
Engine: L69 stock
Transmission: T-5 B-W
This is my daily driver. I'm an idiot and left the ignition on all day and it won't turn over now. It'll crank and the battery is good, but it won't start. I've recently replaced the cap, wires, plugs, pick-up coil and ignition module. Did something get smoked? Like a fuse maybe. Any help appreciated. Thanks.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Left ignition on all day, won't turn over now.
Make sure the battery fully charged it's possible for everything to light up and it to actually crank but not have enough juice to turn the starter fast enough to fire up.
After that's cleared start a list and work down. Does it have fuel, does it have spark... etc.
1 Post
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
unplug the battery, both posts for a few minutes and see if it helps...
your car is carb'ed? right
Car: '84 Trans Am
Engine: L69 stock
Its a five speed camaro newb. It's carbed. I put a jump box on it.. nothing. I disconnected the battery for a minute.. nothing. It has gas. Hairy sox - i've got one coil. I guess I'll check for spark today..
Car: '84 Trans Am
Engine: L69 stock
Sorry sox.. yeah i was thinking it may have smoked the ignition module.. or a fusible link by the starter
1 Post
Engine: 5.1 4bbl
You've got to ask bro... here on TGO there are a lot of modified and hacked up birds... so better to ask up front than in post 75 ... oh by the way the engine is TPI...
Engine: 383 SBC
So the starter is working and the motor turns over but it just doesn't fire up?
Car: '84 Trans Am
Engine: L69 stock
Yes, it cranks, but it will not fire up. I am going to replace the ignition module (Thank god I have a spare) when I finish typing this. We'll see what happens!
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Thats odd. Have you had the battery checked? as in tested at autozone or something?
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
Most refer to "turning over" as the starter spinning the motor. It "cranking" would mean it actually starts.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
cranking
cranking
2crank
verb
Definition of CRANK
intransitive verb
: to move with a winding course : zigzag
a : to turn a crank b : to get started by or as if by the turning of a crank c : to gain speed, momentum, or intensity —usually used with up <the campaign is cranking up>
transitive verb
: to move or operate by or as if by a crank <crank the window down>
a : to cause to start (as an automobile) b : to rotate the shaft (as a crankshaft) of especially with a starter <crank over an engine> c : to use in trying to start an engine <crank the starter>
a : to start as if by use of a crank —usually used with up <she cranked up the air conditioner> b : turn up 2 —usually used with up <crank up the volume> <crank up the stereo>
Examples of CRANK
1. He cranked the temperature to 75 degrees.
2. Crank the engine to see if it will start.
2crank
verb
Definition of CRANK
intransitive verb
transitive verb
Examples of CRANK
http://www.youtube.com/watch?v=fvz3PwBVREo
Modern use of term (Notice that it does not start):
http://www.youtube.com/watch?v=1hftEuPiguQ
Car: '82 Z28
Now comes the 3 pages of useless back and forth talk about the differences between cranking and turning over.
1 Post
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Exactly why I did not try to explain it to TSRAM. Thanks everyone else for clearing it up for him/her though.
Engine: V6, V8
I was going to try to help earlier based on the title but then realized it conflicted with the first post. With the second person coming in doing the same thing, well -I'm sorry I just couldn't take it anymore. Terminology needs to be agreed upon or it's useless trying to accomplish anything. I didn't think there would actually be any dispute over it though.
Engine: 383 SBC
LOL that's why I tried to state it clearly in my question. So did the new module fix it?
