Maybe I am just an idiot...: Need help installing timing tab
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I installed a new timing tab with my new timing cover. But the timing tab is rubbing against the balancer? Can someone show me a diagram as to which bolts on the timing cover are used to hold the timing tab?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What's the diameter of you damper? You may have the wrong tab for the size damper you have.
The_Phoenix
02-04-2016 07:10 AM
