need help on how to drop the distributor!
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
can anyone give me any tips on setting the distributor inside the motor & getting it to point to #1. For some reason I keep coming up a little short & the motor wont turn when i try to start the car. Been stuck at this point for 2 days so Iam open to all suggestions.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help on how to drop the distributor!
https://www.thirdgen.org/forums/tpi/...-question.html
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The rotor can point anywhere when you drop in the distributor - but wherever it points on the cap that's where the #1 plug wire needs to be, then follow firing order around the distributor. It's just that most folks point it towards the #1 cylinder as a reference and reminder.
You just have to make sure you are stabbing it in on the COMPRESSION stroke of the #1 cylinder.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Do you understand now what to do?
Jake
Jake
amargari
11-10-2015 02:09 PM
sreZ28
10-22-2015 08:21 AM
