Will these heads work on my 87 L98 ?
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Thinking about picking these up for my 87 Iroc. What should I look for casting # wise ? I want to make sure these are what this guy says they are . First time buying used heads so any advise would be great.
HI THESE ARE A SET OF ALUMINUM L98 CYLINDER HEADS THAT CAME OFF AN 88 CORVETTE THESE HAVE JUST GOT BACK FROM THE MMACHINE SHOP FRESH VAVLE JOB PORT WORK, POLISH NEW SEALS ROCKER STUDS AND GUIDE PLATES HAVE WAY TOO MUCH MONEY IN THESE SO $550.00 IS A GREAT PRICE PLEASE CALL ********** GREAT UPGRADE TO ANY STOCK TPI AND IT STILL LOOKS STOCK
- it's NOT ok to contact this poster with services or other commercial interests
Engine: 5.7 TPI
Re: Will these heads work on my 87 L98 ?
Anyone ? I want to pick these up but want some expert opinions first.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It's a good price if they're not cracked. Work the deal some way so you're not out any money if they are. And have them checked at any shop other than the one the seller used.
Engine: 5.7 TPI
Thats what I wanted to do . I was just wondering if there are any problem spots . Anything specific I should look for . And wanted to know it they will bolt up to my 87 with the stock intake no problem .
And I am not paying $550 for them . I wheel and deal with the best of them
They will bolt onto your IROC motor. You will lose EGR function though. As you can see from the photos the vette heads have no EGR ports as the vette's EGR fed off the exhaust manifolds.
Engine: 5.7 TPI
Not to familiar with the egr's function . Will this have a negitive effect on my car ?
Guest
Posts: n/a
EGR is an emissions control device, that doesn't hurt power. Used correctly, it can slightly improve gas mileage just enough to measure the difference. You have to keep it if your area does a visual inspection of the emissions equipment, even if it can't do it's job, it has to stay hooked up and appear fully functional.
It only adds about 1 pound to the car, so no worries.
Engine: 5.7 TPI
Well by me this car never has to take emissions ever again but my worries were with the check engine light . Will not having this trip it off?
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Short answer, yes!!!
It will set a code 32!!!
No way to get exhaust gas to the diagnostic switch that tells the computer that EGR was detected due to ECM commanding it!!
P.S. If you install these on your car, you'll have to change your signature from: 87 Iroc-Z 5.7
All stock , Original yellow car to: 87 Iroc-Z 5.7 All most all stock , Original yellow car!!
Engine: 5.7 TPI
Lol Iroc Dan you crack me up .
I am getting the car custom tuned after I would install these so as long as they can work that code out with the tune I will be fine .
Well first you'll need to do a on the spot test. Find a straight egde and put that puppy on the bottom of the head to see if its warped. Nest have the seller go with you to get the heads "magna fluxed." This is the 100% sure way to find out if the heads are cracked. But these heads are missing the EGR passages. Another good use for the EGR system is that there is exaust injected into the intake. The exaust helps keep upper cylinder temps low which helps reduce detonation and premature engine failure.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
As I recall, they don't flow all that well either. There are several sites that have the flow numbers posted and you can check it out for yourself.
http://www.purplesagetradingpost.com...fo/heads1.html
Jake
Jake
Keep looking for a good set of aluminum heads with the EGR passages, they're out there!!
The look of stock, the function of stock, the reliability of stock!!!!
Stock, stock, stock.........stock I tell you!!!
P.S. Nice Camaro (IROC-Z) by the way!!!
