88 GTA 5.7 TPI will not start!!
I have been trying to get this running for a while now and i give up and need your help!!! It turns over it gets spark i checked for pulse with a noid light at every connector the light blinked at all of them. The injectors are all at 16.9 ohms!! The fuel pressure is 42 psi i changed the fuel filter i also tried a different ECM!! I have also checked all pin outs on the ecm for proper voltage and i tried a different ign module and coil!! I just checked for 1.5 volt ref pulse while cranking at a ppl/wht wire!! I have sprayed starter fluid and no go!! PLEASE HELP ME!!!!!
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 88 GTA 5.7 TPI will not start!!
If your getting spark, fuel, and assuming your getting air (I have actually seen air filters so clogged the motor wouldnt start), then the timing is probably off. I would try checking the timing while cranking the motor over.
Some more info on the car may help though. Mostly, what led to it not starting?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had a hard starting issue once and poor idle quality with the TPI setup. Turned out my distributor clamp actually was broke and would rattle the distributor enough it would adjust the timing constantly and retard it like crazy.
Did you change plugs or pull the distributor out before this happened? I'm just wondering if you have the timing out of adjustment or even the firing order off.
i have checked the firing order and i have not removed the dist but i will now be checking for a timing issue!!
Have you verified the timing is correct?
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
I had a problem similar to this. I unpluged the mass air flow sensor and it started fine. It was a bad maf sensor. I can't remember if 1988 TPI's still had the maf.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
What did the plug look like-was it soaked with gas or
carboned up? Also if you shoot some gas or starting
fluid into the throttle body does the car chuff or pop
like it is trying to start? Exhaust verified as clear?
The plug was not very wet but was black and had carbon!! I tried starting fluid and nothing different! Im not sure how to verify if exhast is clear?
Car: 1987 Z28
Did you happen to unplug the maf? The computer has parameters preset for limp home mode. It may start up, but driveability is effected.
Car: '82 z28
Engine: L83 5.7
Several ways to check if there is flow through exhaust:
- rubber band a small plastic sack on each exhaust pipe
and crank-if there is flow the sacks will inflate...
-have someone feel for exhaust "puffs"while cranking
hold throttle partway open for best results...
-take off intake pipe and rubber band a small plastic
sack to the throttle body intake and see if it tries to
suck in while cranking...
Car: 1987 Z28
Have you checked your throttle position sensor? Could be flooding motor. Technical Article: IAC and TPS Adjustment (on this site) can help with testing.
I checked all the settings for those to sensors!! tps .54 volts and iac valve hadd a measurement that i just adjusted!! This thing is making me mental it has all the things that an engine need to run but this thing will not start!!!!!!!!!!!!!!!!
Car: 1987 Z28
Sanjay
08-12-2015 03:41 PM
