HELP. 92 Camaro wont go into gear
Hi, I have an 1992 z28 camaro. I just had headers installed the other week. Got the car home and it wont go into gear. I replaced the slave cylinder and I had a friend come over and bleed the clutch. It worked for a day then reccessed back to not working. Anyone have any ideas?
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Re: HELP. 92 Camaro wont go into gear
ermm.. binding on the gear linkage somewhere? Go along the whole deal and make sure no wires got tangled when they put the headers in, and make sure nothing is "in the way" of the linkages? next bet is pull the tranny and figure out what they put together wrong when they put the motor back in.
db057
08-11-2015 10:11 PM
