Methanol injection?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Methanol injection?
Just wondering if anyone has tried a methanol injection kit on a high compression naturally aspirated engine? I am toying with the idea and have contact snow performance. They claim with the use of one of their kits and some tuning a 5-10% increase in Hp can be made.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: Methanol injection?
ive installed and ran a few diffrent types of meth injection, i like it its kinda like a saftey to high boost. ive never ran it in a na car before. i guess it will allow u to add some more timing, and cool the intake and higher octain= more power!!! snow is where its at, they work the best and have the best kits. i hate anderson motorsports version! the only thing i can tell u is try it some people have good luck and some bad. just make sure u get a big tank for the water/meth because ive had a friend run out and toast a motor.
snow is nice because of the electric pump. and big tank that u can toss in the trunk. the anderson is ran off of vacuum and the tank is small.
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
A local runs it on his 13.5:1 LSx trans am. Its a track/street car and the tank is about 2 gallons. He also sprays a 350 direct on top tho. NA most of the time when he makes the drive to a local hangout.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
there is a few diffrent sizes 1qt and 3 and 5 gallon i think.. and spray on top of the meth injection would be awsome!!!
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
I want to get one of these kits and have it spray into the supercharger to boost octane and quench detonation, as well as keep the inside of the motor clean!
