Trans Am Engine Block # 12465197 (Ac Delco Mexico) What Size Engine? Please Help
Car: 1986 Trans Am
Engine: TPI 350
Hello, I Have a 1986 Trans Am and i can not figure out what size engine is in it??? It says " Ac Delco Model 12465197 Made in Mexico remanafactured for general Motors" i was told it is a 350 out of a wrecked Iroc but? can anybody help! Thanks so much! i can not find info anywhere yet and have been looking everywhere. thanks
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Trans Am Engine Block # 12465197 (Ac Delco Mexico) What Size Engine? Please Help
If it has "Hecho en Mexico" cast behind the left head, on top of the bellhousing flange, then it's probably a basic "Goodwrench" 350 that's now on it's second life, as a crappy 355 with cast dished pistons, 76cc heads, tiny cam, and such.
Car: 1986 Trans Am
Engine: TPI 350
Thanks for the reply!, I put valve cover gaskets on it today and found out the 1986 gaskets did not fit - it has different heads on it i guess, it has the center 4 bolt torx bit style that is used from 87' to 02' wow? wtf? i did not find anything saying "hecho en mexico" but the tag that says remanafactured in mexico is a little aluminum stick tab underneath the head on cylinder # 1 on the driver side- wierd. it also has the cap for a mechanichal fuel pump on the standard passanger side, is that normal? I lived in salt lake for years- in kearns actually, i seen your in logan, whatsssup lol. thanks for any info. . .
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I only moved here relatively recently, and I'm too old for whazzup, but hi anyway.
Seems it's a complete mystery about your engine, so still assume dished cast pistons, and weak rod bolts, so assume a 5500 rpm redline, but pop a valve cover and get us a casting number for the heads.
84z96L31vortec
08-20-2017 12:16 AM
knight72
08-10-2015 09:32 PM
84z96L31vortec
08-10-2015 08:27 PM
