shifting into park issues
so I have this problem which is slowly getting worse where my camaro wont stay in park... now it will go into park and i can remove my key but it will roll. so basically when i shift into park and it doesnt stay i shift back to drive then back into park and one or two times doing that itll stay. anyone know any possible reasons this could be happening?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: shifting into park issues
Could be loose shifter linkage at the trans.
jack the car up and check the linkage bolted to the trans pan under the car, driverside. when it gets loose this happens. Simple fix.
Street Lethal
04-30-2019 12:14 PM
