Starter Wiring
Starter Wiring
I am building my wire harness after swapping a 305 of a 6cyl. The starter motor has a post for a ballast resistor. My old engine didn't have this.
Can someone tell me if I need to wire this up, why and how? Another two weeks and I'll be ready to fire it up!
Thanks,
Steve
Thanks,
Steve
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starter Wiring
Some coils run at a lower voltage (say 9V) and get 12V from the starter terminal direct to the coil bypassing the ballast ( which drops the voltage down ) when cranking only to boost the startup spark.
If the 9V coil had 12V on it full time it would burn out
Re: Starter Wiring
Wow. I had not thought of that. I have an HEI dizzy. I installed a power center from Painless. Its directions say to run a wire from the panel directly to the HEI battery terminal. I have not measured the voltage there, I just assumed it was switched 12v.
So what should be the correct voltage at for an HEI dizzy?
Only if you are using a coil that requires a ballast resistor; you don't state what Ign you are running
Street Lethal
04-30-2019 12:14 PM
db057
08-11-2015 10:11 PM
