87 camaro blower motor
Old 08-06-2010 | 02:33 PM
eldoark's Avatar
my blower motor only works on low speed. Is there a way i can check if its the motor or the switch?... thanks
Old 08-06-2010 | 02:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 87 camaro blower motor
Welcome to TGO. If only the high speed is not functional, check the relay.
JamesC
Old 08-06-2010 | 02:54 PM
eldoark's Avatar
med or high speeds do not work blows at the same low speed no matter what ypu put it on
Old 08-06-2010 | 03:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Like said, check the relay - it's under the hood on the blower box. Might also look at the resistor, it's on the box as well - little polygon looking piece that is held in with two 7mm screws.
Otherwise, might be the switch itself, but the first two are easier to check/replace. If you go into the panel to look at the switch, be careful not to pull any of the vacuum lines off the assembly - there's a slew of them back there to adjust vent doors and such, and the General didn't give us much (if any) slack to pull out the assembly.
Old 08-06-2010 | 04:09 PM
eldoark's Avatar
great thanks for the info. ... Ill check the relay and the resistor
Frozer!!!
01-19-2024 05:55 PM
sweet_87_iroc
Exterior Parts for Sale
03-27-2016 05:05 PM
Street Lethal
08-13-2015 09:28 PM
85Iroc-Z
08-13-2015 02:58 AM
slade5612
08-11-2015 08:19 PM
