speedo not working
speedo not working
ok i knew my speedometer wasnt working i assumed it was the speed sensor and had plans to change it but i noticed my odometer doesnt work either...my tach and other gauges work.. any help and/or ideas are appreciated
Honchoblake (05-22-2021)
Re: speedo not working
If your speedo isnt working due to the speed sensor, the odo isnt going to work either. The speedo and odo are together in the same unit and get their info from the speed sensor. The only way a odo would work with a speedo not working is if the actual speedo itself were broken.
Yes. There is a test for the electronic speedo. As vetteoz said, I need to know what year, model engine and trans to help you with that.
i could use a little help in this area also. i have a 87 irocz with the 5.7 tuned port engine and the speedo just suddenly stopped working. after driving for a little while the mil light comes on. just wondering where to start before i start pulling things apart on my own. thanks
Welcome to TGO. Since you have a mechanical speedo, the following link should provide the info you need:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
JamesC
would that explain the mil coming on? I was searching on here how to pull codes but cant seem to find a clear explanation on which terminals to jump either, i keep finding mixed answers. A little more info would be great... sorry to be a pain.
Yes. Very likely culprit.
The proper method for testing the VSS is to use a scanner to read vehichle speed. The VSS produces an AC signal which the VSS buffer converts into digital pulses. It is possible to use a voltmeter to test for voltage at the VSS while running the car, in gear with the wheels lifted. PLEASE BE CAREFUL!! When doing this. Make sure the car is securely supported and stay away from the turning wheels.
Look for AC voltage at the sensor. If there is none, remove the VSS from the trans and spin it with your fingers while watching for AC voltage. If there is no signal when spinning the VSS, replace it. If you get a signal when spinning the VSS by hand, check the speedo drive gears on the sensor itself and on the output shaft of the trans.
This is another case where it really pays to have a scanner. A Snap On brick, which is an excellent scanner for the 3rd gen, can be had for as little as $300. I cant think of a better value for the price.
The speed sensor is seled with a rubber o-ring. Just replace it with he same size o-ring. There are several scanners that will work on the 3rd gen. My favorite scanner for these older cars is the Snap On brick. They are available used on e-bay or from your local Snap On dealer. They run about $300. The 3rd gen is OBD1. It takes a GM OBDI interface adapter to connect to the 12 pin DLC. Make sure whatever scanner you buy has this connector.
To read codes, jump terminals A&B in the DLC. They are the two terminals in the upper right hand corner.
Car: 89 camaro
Engine: 5.7 from an 89 blazer
hey bro i just jumped mine its the two on the top right corner i used a safety pin i was worried id do it wrong but it worked if you need help let me know ill tell you how
Car: 89 camaro
Car: 1992 RS
HEY! im having issues too!! Except, my speedo jumps. Itll bounce between all the dwn and the speed im doing. Well it used too. Nw, itll bounce a lil. And thats it. BUT! My gas gauge started wiggin out too. Like, About a week r two it was reading 1/4 of a tank fuller than it shldve been. Then went to normal. And about two days ago, it pegged ALL the way out. Went from almost empty, to past full, and hit the plastic gauge lay over. And my oil pressure gauge, sometimes itll read 30 psi higher than it shld. Like. Itll read 60 psi drivin and the line before 60 idle. When it normally reads 30 idle and the line before 60 idle....
P.S. Its a 92 camaro, 305 tbi, SHLD BE 700r4.
THANKS!
Edit!: ONLY that half of my dash cluster is wiggin out. My tach, temp, and volts never mess up. That i know of. Any advice is appreciated! Thanks!
THANKS!
1 Post
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
having the same problem with the speedo/tach/gas gauge
Speed/tach do not work at all. Tach guage is topped out and speedo guage reads 0mph all the time. This thread got a little confusing when one guy said the VSS was on the transmission & another said it was behind the cluster.
Which is it? & should my Cruise Control & Odometer be working if the speedsensor is out?
& is the VSS an abbrivation for vehicle speed sensor?
91 rs 305 tbi
91 rs 305 tbi
Car: 1986 IROC-Z28
Engine: TPI 305 Bone Stock
Axle/Gears: Posi-Trac
Would the speed sensor also effect my acceleration? When I start the car up it revs itself up to about 2k rpms. I can't know for sure since the tachometer is'nt working but I can tell its revved.
Sometimes it's revved up the whole time I'm driving it so I'll be at a light with my foot on the brake and I can feel the car over accelerating. Other times it works normally.
1991 rs 305 TBI camaro
beachrodder
08-07-2015 04:27 PM
3rd, 700r4, 89, camaro, connection, gen, sensor, spedometer, speed, speedmeter, speedo, speedometer, spinning, stop, thirdgen, working, workingthirdgen
