Will this make my 305 tpi faster
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
Re: Will this make my 305 tpi faster
any stepped up cam from stock will obviously make you more power, unless you dont have the neccessary mods to back it. that is a mild cam and should be able to run on a pretty much stock set up.
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
what year is your car? if i remember right in 87 they switched to a roller cam, that is a flat tappet
Engine: 5.0 TPI
Engine: 305TPI
well he did say its a 305tpi in the thread title haha.
Engine: 305TPI
i belive it should work, let the pros chime in though. but dont expect an HUGE jump in peformance because i belive 85 tpi's already had pretty decent cams, but it will help.
Car: 1986 IROC
Engine: 355" TPI
That cam is not worth installing. You need one with more lift and duration.
Car: 1986 IROC
Engine: 355" TPI
Sanjay
08-12-2015 03:41 PM
