No hot restart
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
No hot restart
what can cause a car to run flawlessly but not restart when warm? i have a 1990 T/A 305 TPI and it has a new injectors, new distributor, a new ign module, new pickup coil, new plugs and wires, new accel cap and rotor and msd coil. I can drive the car until its operating temp, turn the car off and then try to start it again and it will just turn over and over and not start. i have found that i can let it sit for about 10 secs in between starts and it will fire up...this has me baffeled what can be causing this???
Car: 1990 Trans Am
Re: No hot restart
Sorry i forgot to add that i have 43 at rail and 38 while cranking fuel pump was replaced about a month ago
Car: 1990 Trans Am
Re: No hot restart
i checked the pressure again today and im still getting the same numbers
Car: 1990 Trans Am
Re: No hot restart
UPDATE car did not start again today but i unplugged the coolant temp sensor and it started like nothing was wrong do you think that i found my problem?
Car: 1990 Trans Am
Re: No hot restart
i replaced the cts but it still does the same thing and it did it today when the engine was cold,let it sit for a min and it fires right up it also runs lean and i have a vacuum leak
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
Re: No hot restart
no these cars are notorious for heat soak issues...mine does it also....i have done everything. changed fuel pump, installed carb heat spacer, wrapped fuel lines by header....etc. (by the way i have a carb setup) i guess depending on the year...the dealership used to have various tsbs...on this issue....let me know if you ever find anything or figure it out...i never have...
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
Re: No hot restart
mh82camaro, what carb are you running. Either way this happened with my holley. All I did was lowered the fuel level and I was good to go. See there was too much fuel in the bowls. Just a suggestion.
Re: No hot restart
i am running a 600cfm electric choke edelbrock....like i said...i bought fuel line heat wrap, new stock style pump, the heat spacer under carb....it only does it when it gets hot and it sits for a while....example....going to dinner after a cruise...yeah let me know what you did....im interested
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: No hot restart
first thing SEARCH
this is one of the most common topics in the summer month and you will find all sort of common problems and fixes.
