Oil filter relocation
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Just a couple of questions, I am learning. I bought Mocals oil thermostat to use with my oil cooler. Its the one that bolts to the block above the filter. It wont clear the custom y pipe I had made for my LS1 swap.
This leads me into my question. I have the thermostatic sandwich adapter that came with my oil cooler. I was thinking of doing a filter relocation, (because with the sandwich adapter my filter hangs dangerously low to the ground) and use the sandwich adapter on the relocated filter.
I have been told that oil will drain back from the relocated filter and I will not have oil upon start up.
Is it as simple and using a one way check valve to prevent the oil from draining back and having proper oil upon start up?
If it isnt a good set up then I will get my y pipe redone. Thanks.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Oil filter relocation
I don't know about anyone else, but I'm just gonna need pics if I'm gonna venture an opinion.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
My l31 came with oil cooler also in the same place, the machinist I used advised me to get rid of the oil cooler. Since its a street car he said the cooler was not worth the trouble like what your going into. So I junked it,and bolted filter adapter to the block.
Hotrodboba400
12-10-2019 07:07 PM
89 formula TPI
09-07-2015 11:06 AM
4l60e, adapter, camaro, filter, hangs, low, ls1, motorsports, oil, outback, pan, relocate, relocating, relocation, thirdgen
