87 firebird manual motor knob won't raise headlights
Old 07-22-2010 | 01:34 AM
pghsmoke's Avatar
87 firebird manual motor **** won't raise headlights
Hi,
I have just bought an 1987 firebird. The lights do not raise but the motor sounds like it is spinning the shaft. I assume i need the common fix using the three inserts. But i can not get the lights to raise, lifting up on them and using the manual motor ****. I do not want to pull really hard and break anything. Any one have an idea as to what the hang up might be?
Old 07-23-2010 | 07:11 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Re: 87 firebird manual motor **** won't raise headlights
I had to take off the caps and use pliers to turn the ***** because they were stripped, mabye that will help
Old 07-24-2010 | 06:19 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
yeah they strip out over time, i had to take my friends and just unhook them, open them and lock them up like that
Old 07-27-2010 | 03:03 AM
91nunifb's Avatar
forgive me for hijacking the thread, but how did you lock them up? i want to do exactly that.
Old 07-27-2010 | 04:25 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Open it up And jam the gears, if you want it permanent use some superglue there's probably a better way but I don't own a bird and haven't had enough time to tinker with it
1992 Trans Am
05-10-2023 08:19 PM
jhawkeye
05-25-2022 07:33 PM
BRoss99
12-07-2020 07:50 PM
OLDYELLR
Car Audio
09-30-2015 08:10 PM
slade5612
08-11-2015 08:19 PM
