Head gasket job on 350
Hello, I'm doing a head gasket job on my buddy's trans am. I have a few general questions. I bought some head bolts for my 305 camaro, I compared them to the head bolts that came out of the 350. The bottom ones matched up perfect, but the head bolts that go under the valve cover appear to be about a half inch shorter...
1. Do you think the head bolts will still work even being a little shorter?
2. Does anyone know the torque specs for the head bolts?
Car: 86 iroc
Engine: 355
Axle/Gears: .323?
Re: Head gasket job on 350
THE HEAD BOLTS ARE 3 SIZES. MAKE SURE U PUT THE RIGHT BOLTS IN THE RIGHT HOLE.70LB CAST IRON.START AT 45LB. 55LB 70LB
ambainb
04-25-2016 09:21 PM
NinjaNife
08-23-2015 11:49 AM
