Hot cam in a 355 TPI
Car: 89 Trans Am
Engine: Stealth Rammed 355
Axle/Gears: 10 bolt 3.23
I was wondering if i can i use a lt4 hot cam in a 89 355 tpi. Because on the summit website the hot cam they offer it says that it is not computer compatible, so do i need a cam that is computer compatible? If it is a matter of prom tuning that doesnt matter to me because i am going to be burning my own chips
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Re: Hot cam in a 355 TPI
Plenty of members have LT4 hot cams in TPI powered engines. This cam was made for the LT1 which is computer controlled. Don't know if the one you saw was made for carbs but I doubt it. I'm assuming by non-computer compatible, they mean the PROM just needs tuning.
Car: 2011 6.2 Silverado, 88/85 camaro
Call Summit, they have a number for tech questions like this. Could mean that it is not compatible with the stock ECU, would require tuning as the previous poster has said
Car: 89 Trans Am
Thats what I thought it meant but I was not sure, Thanks guys
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
For the record, the Hot Cam with 1.6:1 rockers is also not compatible with stock Vortec heads.
84z96L31vortec
08-20-2017 12:16 AM
Sanjay
08-12-2015 03:41 PM
84z96L31vortec
08-10-2015 08:27 PM
