Gas cap wont screw on?
Car: 87 Z28
Well I did a quick search, didnt come up with anything. I need some help asap as I can't drive without an answer
Basically, sometimes when I fill up my tank, I can't for the life of me screw the gas cap on. It can usually go about 2 turns and then does the click thing. I cant feel behind the cap that it still has a ways to go to be completely on.
I filled up and drove home thinking it was on enough (I stood at the pump literally trying to get it on for 5 minutes.) My driveway is on a slant, and the way it was sitting I could see gas coming down below the gas door. Soooo basically I cant get the cap to screw on. It hasnt been a problem since the weather got a lot hotter, so I'm assuming something is expanding from the heat.
I had to pull the car on to the road so gas wasnt basically pouring out of my tank.
Any ideas? I need to use it later so I can't be driving around leakin some gas.
I feel this should be easy, maybe I'm just stupid. Couldn't find anything on google
Car: check
Engine: check
Transmission: check
Re: Gas cap wont screw on?
I had the same issue with the stock factory gas cap. Mostly in hot weather it would tighten & click well before being seated. To the point where it would hold the gas cap door open some.
To fix it I used a flat file and a round file on the gas cap threads.
With the flat file I knocked down the OD of the threads. Not a lot, a guess about 1/16".
With the round file I lowered the grooves in the valley of the threads. Just the very bottom of the grooves, and again not a lot.
Basically this makes the minor & major OD of the threads less. Being plastic it is quick & easy.
It did the trick. Haven't had an issue with the gas cap since.
RBob.
RBob.
Car: 87 Z28
RBob.
RBob.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep it does that, seems like you just gotta try again, like it can start cross threaded or somthing. Took me 2-3 tries at times.
Maybe a slather of grease on the threads........
But now I have a cap that has a flap or door in it so ya don't hafta remove it but I know what you mean....
1992 Trans Am
05-10-2023 07:19 PM
