Distributor Gear Size
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
For my current engine build, I have decided to get a new composite distributor gear. What size gear do I need to get? .491 or .500 diameter shaft? It has a factory coil in cap HEI distributor. Thanks
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Distributor Gear Size
all of the factory HEI's that ive had to deal with (1987 and up) have a shaft diameter that is smaller than .491 and .500. i had to go junk yard shopping for a different gear or wait for a part out of canada.
Car: 85 Iroc-Z
My distributor is the pre 87 model. Anybody know the size for that one?
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Edit: to clarify, yours will have a .491" shaft
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
