EGR Vacuum Solenoid?? Rebuilt 350 Engine Fire
Car: 89 Chevy Camaro IROC-Z Convertible
Engine: 350 Corvette Heads bored .30
Axle/Gears: 2.77
I rebuilt the engine in my 89 Z Convertable with a new 350 block but reusing the TPI system from my ttop IROC. After driving it for 2 weeks a fuel line busted and the engine caught fire near the distributor and coil. I was able to get a new distributor and coil etc. but I'm having trouble finding the EGR Vacuum Solenoid. Do I have to have this for the engine to run?? I have tried every junkyard I can find to get one but no luck yet. I found a couple sites that are selling them but they either want 120$ or there showing it for a 5.0 or TBI engine? Do I need to replace this thing or not its burnt to heck and if so can someone suggest where to get one?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
305 and 350 TPI use the same part.
You don't need it to run, but you should have it in order for the engine to run properly.
theshackle
09-17-2020 09:26 AM
theshackle
03-05-2017 07:37 PM
backtothe80s
09-05-2015 01:39 AM
