HELP!!!!
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
HELP!!!!
i have a 90 camaro rs with the 3.1 v6 i was having problems i replaced alot of parts such as
knock sensor
oil pressure sending unit
all vac lines
cap
rotor
pcv valve
pickup coil
alternator
battery
and reset the timing
it drove fine for two days now it is throwing code 35 and 44 and there is black smoke coming out of the pipes it seems to be running good good idle decent amount of power but after it gets warmed up it throws the codes and starts smoking pretty bad any help on this would be great because i need this car on the road asap as its my DD thanks
knock sensor
all vac lines
cap
rotor
pcv valve
pickup coil
alternator
battery
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: HELP!!!!
Have you checked your O2 sensors yet? 44 is O2 lean. The engine will run fine when it's cold because it's in open loop and not using the O2 sensors for tuning because they take time to warm up to operating temp. Once the engine and o2 sensor(s) have warmed up it will go into closed loop. Closed loop uses the O2 sensors in combination with other sensors to supply the ECM with information about how the cars running. The black smoke you are getting is an overly rich condition. Check the O2 sensor(s) or just replace them. Should be only 19$ each. If the ECM sees a bad O2 sensor saying the engines running lean, it's going to respond by adding more fuel to keep the engine from detonating. This causes the engine to run very rich and produce the black smoke you are seeing.
Code 35 is most likely a result of this as well. 35 is: Idle speed can not be set to desired RPM. The ECM has a desired RPM programmed into it. It trys to keep the engine at this certain speed while idling. If the mixture is off (to rich) there's a possibility the ECM wont be able to keep the idle at that desired rpm.
End conclusion: New O2 sensor(s)![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Also, I would double check your timing once more to make sure everything's perfect!
Engine: 3.1 v6
Re: HELP!!!!
Engine: 3.1 v6
Re: HELP!!!!
see i would put a 350 in it if i had the time the money and wanted not so good mpg. as far as im concerned the 3.1 is a great motor yeah they dont make it a street rod by any means but they definatly have some getup and go with the proper parts.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Note from your local friendly moderator:
Keep your responses in accordance with Board rules. That means on-topic.
That also means keep your responses to rules-violating posts within the Board rules.
Violate the rules, your posts will be deleted.
At the very least. . .
