Thinking of purchasing this but
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
I want to purchase this:
http://www.summitracing.com/parts/CCA-SK12-242-2/
but want to know if itll require any type of machine work to my lo5 swirlports (I know).
I have the money for the cam but no money for any type of machine work.
Also is this a good choice in cam for a car that'll see mostly street, and a little strip. looking for around 300-400hp with no power adder
Car: 1990 RS Camaro
Engine: 305 TBI
Re: Thinking of purchasing this but
sorry i meant this kit
Car: 1990 RS Camaro
Engine: 305 TBI
from what ive read, no machine work is required. the website just threw me off when it said head machining required
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I run the same cam. My heads were already machined for bigger valves and .550" valve lift clearance when I got them though. I think that cam is as big as youll be able to go using stock ratio rocker arms without having to machine the heads for more lift. You will however have to change the valve springs and rocker arms. I just so happen to have a spare set of the comp cams springs you need for that cam taking up space in my closet. Its the full set of springs, steel retainers, and steel valve locks. They were used for about 1000 miles on a friends engine before he blew it up, but they are in perfect shape.
Car: 87 & 88 Formula
Engine: 334 stroker
Axle/Gears: 9 bolt 3.70 gears
that is an awesome street cam. But if your car is still EFI, it will not work. carb only
Car: 1990 RS Camaro
Engine: 305 TBI
Why only carb'd? the comp website offers variations, one for carb, tbi, tpi, bigger engines, smaller engines, I got the one for 350 tbi.
Engine: 334 stroker
another thing, with a cam like that its better to run a lower gear ratio. 3.42 at a minimum. 3.73s would be better. and a higher stall converter like a 2,400
Engine: 334 stroker
i thought you were looking at that exact one. as long as its compatible, your good
Engine: 334 stroker
I thought you were looking at that exact one. as long as its efi compatible, your good
Car: 1990 RS Camaro
Engine: 305 TBI
I would need a computer controlled cam correct?
I checked the website again and they only have the one in the link, a tpi version, and one for big block.
Here is the selection... will any of these fit my car? I need to keep it tbi because california emissions
---sorry cant get it to link---
Car: 1990 RS Camaro
Engine: 305 TBI
Engine: 334 stroker
is your engine completely stock? also, are you still running the stock injectors? what are your plans with it. if u can tell me your setup, then i can help u pick out a cam to fit your needs
Engine: 334 stroker
efi engines need a lobe seperation like a 112 -114. they dont anything tighter like a 108 or 110.
Car: 1990 RS Camaro
Engine: 305 TBI
I currently have the engine out of the car. It is a stock lo5 with the basic swirlports.
My mod after a good cam is vortec heads.
I want to keep it a smog legal as I could. what I mean is sniffer legal, visual doesnt really matter.
I want to do hooker 2055's > 2055 y-pipe > cutout before cat > stock exhaust.
I want my car to be a semi daily driver, but also a strip beast.
Im looking for about 300 mid-high range hp.
I'm not to good with chevy performance yet but I know how to work on an engine.
Car: 1990 RS Camaro
Engine: 305 TBI
Car: 91 Camaro RS
That cam has a lift of .480". If I'm not mistaken, the stock heads can handle about .460" of lift, anything over that and you gotta machine the guides to handle more lift.
Car: 1990 RS Camaro
Engine: 305 TBI
the person who posted above you is running this same cam and it fits but I couldnt go any bigger than this lift
Engine: 334 stroker
what kind of compression are u plannin?
Car: 1990 RS Camaro
Engine: 305 TBI
more then likely 9.5:1 or 10.0:1. If I go with 9.5:1 I would want to build the car to be able to handle a power adder, more then likely a supercharger. But I dont have that kind of budget so I may just go with higher compression
Car: 91 Camaro RS
Well I found this and post #3 is saying that .480" of lift is the max you can safely do on stock swirl ports.
Engine: 334 stroker
if you go close to 10.0 with that cam, Vortec heads, and a good int manifold, you should be close to 400 hp. i think you'll be really happy with it. there's mods you must do to the tbi unit to support that kind of power. that tbi is your biggest restriction. check out the tbi section, there's tons of info there on what to do.
Engine: 334 stroker
and i do agree with travis, i think u need to have them machined.
Car: 1990 RS Camaro
Engine: 305 TBI
Oh Ya I know that article front and back... That'll definitely be my next mod.
As for the engine. I believe a rebuild is in order.. I dont think I can survive on stock 8.3:1 compression
Car: 1990 RS Camaro
Engine: 305 TBI
well Im not paying to have these heads worked on when Im going to swap them out anyway so Im just going to buy the cam and parts, if it doesnt fit, im saving up for vortechs
Engine: 334 stroker
the vortec heads with that cam is whats goin to make the difference. they should work together nicely. your not going to be able to take advantage of that cam with those stock tbi heads. if your on a really tight budget and you have to run them, id pick a little smaller cam.
Car: 91 Camaro RS
Seeing as Im running the vortec heads, Im gonna agree with that statement
Car: 1990 RS Camaro
Engine: 305 TBI
I just read an article where a guy upgraded his cam ad rockers, giving him a max lift of .488. Everyone said he should have no problems with that much lift. I think Ill be fine. Im not giving up on vortecs, I just cant afford it
hectre13
08-26-2015 08:17 AM
Thornburg
08-25-2015 01:46 AM
