What is the correct engine rpm at 65 mph?
Hi, I am the owner of 2 1989 Iroc Z28's. I just bought one with the L98. I want to figure out if the previous owner installed a larger rear end gear (lost contact with original owner). My Camaro with the LB9 has a 2.77 rear end gear and runs almost 1700 rpm at 65mph. The Camaro with the L98 says on the parts sheet in the console that it has a 2.77 rear end gear and runs 2400 rpm at 65 mph. Here's an issue with the L98 camaro, the vss doesn't work (mph gauge not working), and I was using my GPS to tell me when it was running at 65 mph when the rpm gauge was at 2400 rpms. I can feel my car shifting into overdrive. So is not having a working vss messing with the rpms, am I running a higher gear, or is it normal for a L98 to run higher rpms than the LB9 at 65 mph with a 2.77 rear end gear?
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: What is the correct engine rpm at 65 mph?
My next question is, What rpm are you L98 guys running at 65 mph with a 2.73 or 2.77 rear end gear?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The stock tachs are notoriously inaccurate at this point. I wouldnt trust them at all.
Engine: 5.1 4bbl
you know... I should have mentioned this... but ... you should check your RPM with a timing light and then compare the numbers... ....
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Counting the number of times the driveshaft turns in relation to one turn of the wheel will ballpark rear end ratio
Do the maths
http://www.bgsoflex.com/rpmmph.html
I did some messing around, looks like someone did swap in a 3.73 gear. Thanks!
Do the maths
Do the maths
On Probation
Engine: several
Transmission: none
Axle/Gears: none
With a 3.73:1 axle, and 245/50R16 tires, and a 700R-4 automatic, you should be doing 2200 rpm at 65 mph if the converter is locking as it should. This calls for a 15 tooth speedo drive gear, and a 44 tooth driven gear.
eightsixseven
08-14-2015 03:09 PM
