tv cable bracket
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
tv cable bracket
does anybody have pics or idea what kickdown bracket will work on an edelbrock performer intake and carb? i was told to use the ones that bolt on the carb. anybody got pics or suggestions? thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tv cable bracket
I used this one:
http://www.summitracing.com/parts/EDL-8030/
Had to drill a hole in it to get the TV cable a little closer to the carb, but it's a nice hefty strong bracket that doesn't flex any with the pressure of the TV cable tightening. BUT - it's manifold mounted, not carb mounted.
And be sure to get the TV cable geometry corrector that attaches to the carb linkage:
http://www.summitracing.com/parts/TCI-376710/
Summit makes their own brand, just forgot how to correctly search their site to find it.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 355
anybody use the summit brand bracket? part number http://www.summitracing.com/parts/SUM-G1414/ it bolts to the carb and is adjustabe. also is it the closer to the carb the better? i have the tv corrector bracket for carb, and my stock bracket dont work it bends it sideways. should i fab up mine or buy an adjustable type?
Car: 82 Z28
Transmission: T400
Custom made my own stronger adjustable one , back braced off a intake bolt so it don't go anywhere using the accelerator mount from the original bracket because that does not have so much load on it as the TV cable
TV cable mount has to be correct distance from pivot on linkage so as to operate correctly.This distance is not variable if you want TV to operate as it should
Engine: 355
anybody got a picture of the tv setup? i wanna get it correct but dont know if i got it right
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
def. would like to see a picture...BUMP on that! And do you have to have an edelbrock manifold for that EDL-8030 to work or will it work on a GM style intake???
Car: 82 Z28
Transmission: T400
dbrochard
09-25-2015 04:56 PM
///DAN///
09-25-2015 02:15 PM
