Fixing a sending unit
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Fixing a sending unit
once the contacts wear off the only way to fix is to replace.
My 88 GTA had a bad sending unit. I was able to repair it, because the reason it had failed was due to excessive deposits that had built up on the 'wiper' assembly.
You need to have good hands and patience. It helps to have experience working with delicate parts.
I carefully disassembled the wiper assembly, soaked everything in brake cleaner, and then gently cleaned the wiper surface and the contacts.
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
Is replacing the sending unit a easy job? Is there anything I sould know?
Mine is leaking, and if its a easy replace, I can do it myself. Just wanted to know how to do it. Thanks for any help!
86CamaroDan
09-29-2015 10:08 PM
UltRoadWarrior9
09-02-2015 08:24 PM
