New Springs for XFI cam?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am putting an xfi cam into my new motor that I am building and im not sure if I should put the recommended springs from comp cams on or not. The AFR heads that I have are rated at 340#'s and the Comp Beehives that they recommend are rated at 313#'s. Should I be fine sticking with the stock AFR springs?
86CamaroDan
09-29-2015 10:08 PM
