what head gaskets to use
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
next week i will be changing my heads from the vette 113 58cc to afr 1040s 65cc not sure what head gaskets to use to keep compression 10.1 to 10.5 will the mr gasket steel shim coated do the trick 028'' my motor is 30 over bore with flat tops.. stock deck just cleaned up. lite mill... my cam will be the comp 280xfi...
Car: 1986 IROC
Engine: 355" TPI
Re: what head gaskets to use
Whats the thickness of your current gasket? The .028" ones should help if you have the common rebuild .040" gaskets.
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
ambainb
04-25-2016 09:21 PM
3rd gen money
09-08-2015 11:40 PM
355tpipickup
08-27-2015 08:13 AM
NinjaNife
08-23-2015 11:49 AM
