power steering pulley install
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I've seen the installers that you thread into the pump, but my pump has a hex opening in the shaft. Is there a tool designed for this kind of pump?
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: power steering pulley install
There are threads farther down inside the hex shaped hole. You just need a regular power steering pulley installer. The hex shape is apparently only there for when its assembled at the factory.
Car: 90 RS
If they were there before, they def aren't now! So I guess I'll just get the installer and hope it threads in there good enough to get the job done.
evilstuie
01-09-2020 08:29 PM
colton_carlson
03-08-2019 12:21 PM
backtothe80s
09-05-2015 12:39 AM
Navy8125
08-22-2015 07:13 PM
90, camaro, fbody, gen, hex, install, installation, installing, lt1, power, powersteering, pulley, pully, steering, tool
