motor sounds like its eating itself
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
ok guys my newest delimma. i took the motor out to fix 6 bad freeze plugs, i changed the rear main seal and the valve cover cover gaskets, and the oil pan gaskets. now i put the motor back in hooked everything up, went to start it and it sounds like metal on metal contact and then i got vapor lock symptoms. i filled it with new oil and antifreeze, also new spark plugs. i have a 305 4bbl carb, mostly bone stock. any help would be great guys.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: motor sounds like its eating itself
Drop a bolt down the motor?
Engine: 350 4bbl
hey not that i know of all we took off were the valve covers and oil pan and replaced the carb to intake gasket.
