starter options
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
starter options
i just came across some money so im trying to fix all the kinks in the iroc. i keep going through autozone starters with these hooker headers. what do you suggest i buy. do they sell a starter with a remote mount solenoid for my 5 speed 350tpi iroc
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
Re: starter options
You could try a mini starter. Personally I don't have any experience with them (yet) other than having an LT1 mini starter installed on my 305 (haven't gotten as far as to fire it up yet). A lot of people say the mini starter has enough clearance to the exhaust to not even need a heat shield. Not sure if it's true or not, by mine has some pretty good clearance to my hooker headers (2055). I bought mine off of eBay. There is a company there that manufacturers reproduction LT1 mini starters, and it only costs half of what the cheapest mini starter does from summit. Or if you're still adamant on keeping the autozone starter you could invest in a proper multi-layered heat shield.
Hope that helps.
Hope that helps.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: starter options
I run a Jegs mini starter, hi torque, it's a good unit have it on my 383, w/ no problems for 20K mi. Part No. 555-10001, cost is $139...
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: starter options
no i donot want the **** autozone starter. i installed a new one 3 days ago and already when it gets hot it cranks like ****. if i bought the mini starter jegs brand do you guys suggest also using a heatsheild if so what kind
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I've never heard of a starter with a remote solenoid. But, you can convert a starter to remote solenoid. I just wouldn't recommend it with a permanent magnet motor starter.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: starter options
then what do you suggest honestly id rather spend the extra cash then deal with this later on. part numbers would be greatly apreciated also do you think some kind of heat sheild would be unessesary
Engine: LS1/LQ4
Re: starter options
This is what I used http://www.summitracing.com/parts/SUM-G1750/ . It's fairly easy to install, click on the "instructions" link on Summit's page for details (you won't have an "R" wire). I didn't have to lengthen the factory wires, just unclamped them from the bell housing clamp and routed them to the fender liner where I mounted the remote solenoid.
I've got coated Hooker headers, but I don't think a shield will help much if you're using a remote solenoid.
Re: starter options
I have no heat shield and have had no problems....
Denricci22
09-18-2015 09:02 AM
