California Smog Legal Mods for v6 and v8
Car: 1987 camaro rs limited
Engine: 2.8 ltr multiport fuel injected
Transmission: th700r
Axle/Gears: 3.43
I just want to know if people can list CA smog legal mods for people like me to use on there cars in the worst state to live in. ![go crazy](https://www.thirdgen.org/forums/images/smilies/go crazy.gif)
Im not just talking about bolt on's
I want block building,head work,cams,cranks,rods,lifters,ignition,nos,turbo,superchargers,blowers,
fuel delivery,exhaust work,headers,intake work,bolt ons to.
Even ways to cheat the smog laws![get banned](https://www.thirdgen.org/forums/images/smilies/banned.gif)
I just want people to know what they can do and learn my self
please state is its for v6 or v8 or both
Ill be the first to say that this should be a sticky
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: California Smog Legal Mods for v6 and v8
They make 305 stroker kits. Expensive and not as great as having a 350, but it will get you by without being noticed for having a swapped block.
http://www.speedomotive.com/s-8-small-block-chevy.aspx
Edelbrock also makes emissions legal headers.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No point in listing serious perf. parts for V6s, because if you're serious about performance, you're getting the V8. If you're serious about that, then swap in a LS9. 638 HP. If that's beyond your budget, you'll still get the best HP from some sort of LS swap. But if you insist on a traditional SBC, you can get there with a stroker LT1 with an Extrude-Honed Edelbrock intake, AFR 195cc "Cometition" port heads, a custom-ground cam, SLP 1.75" headers, and a ProCharger. That'll get you to 700 crankshaft HP. If you have the $$$$$$$$$$$$$$$.
Axle/Gears: 3.43
engine swaps are legal in CA but are hard expensive and in most cases the state will not allow the smog change they have to be at least 1 year newer and have all the computer emmisions and come from the same type of car i.e. car to car truck to truck no car to truck truck to car engine swaps. crate motors are illegal on smog cars and considerd "stollen" engines if you get caught on the street especialy v6 to v8 thay wouldnt probably even ref your car the only swaps ive herd of in that caliber is a ford 5.0 in the mazda rx7
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
you can swap a v6 for a v8 in cali you just have to get the car smog check again to register it. I have a 89 2.8 v6. as far as bolt ons go here's the list of what I have...and it's all legal.
Acdelco rapid fire, Pacesetter headers, magnaflow high flow cat, dynomax exhaust, jet stage2 chip, 180deg thermo,jet 4th gear lock up delay module (700r4), msd cap and rotor.
that's what I have so far. next is msd 6al box and ignition coil, truleo intake, 19lb injectors, compcam timing set and a serious dyno tune.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '87 Z-28
Engine: LT1-topped 400
Couldn't you just swap in a 383 and tell them it's the 305? I doubt they're gonna go hunting for casting numbers...
In fact, I can't think of a reason you couldn't do anything as long as it looks stock and passes smog
